[postgis-devel] ERROR: function extent(raster) does not exist
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Mon May 2 06:23:09 PDT 2011
Was the extent(geometry) function removed?
Pierre
> -----Message d'origine-----
> De : postgis-devel-bounces at postgis.refractions.net [mailto:postgis-
> devel-bounces at postgis.refractions.net] De la part de Sandro Santilli
> Envoyé : 2 mai 2011 09:21
> À : postgis-devel at postgis.refractions.net
> Objet : [postgis-devel] ERROR: function extent(raster) does not exist
> A lot of raster tests are failing here, pretty much
> all due to 'function extent(raster) does not exist'.
> Here's a list:
>  rt_above. failed (diff expected obtained:
> /tmp/pgis_reg_32471/test_28_diff)
>  rt_below. failed (diff expected obtained:
> /tmp/pgis_reg_32471/test_29_diff)
>  rt_contained. failed (diff expected obtained:
> /tmp/pgis_reg_32471/test_30_diff)
>  rt_contain. failed (diff expected obtained:
> /tmp/pgis_reg_32471/test_31_diff)
>  rt_left. failed (diff expected obtained:
> /tmp/pgis_reg_32471/test_32_diff)
>  rt_overabove. failed (diff expected obtained:
> /tmp/pgis_reg_32471/test_33_diff)
>  rt_overbelow. failed (diff expected obtained:
> /tmp/pgis_reg_32471/test_34_diff)
>  rt_overlap. failed (diff expected obtained:
> /tmp/pgis_reg_32471/test_35_diff)
>  rt_overleft. failed (diff expected obtained:
> /tmp/pgis_reg_32471/test_36_diff)
>  rt_overright. failed (diff expected obtained:
> /tmp/pgis_reg_32471/test_37_diff)
>  rt_right. failed (diff expected obtained:
> /tmp/pgis_reg_32471/test_38_diff)
>  rt_same. failed (diff expected obtained:
> /tmp/pgis_reg_32471/test_39_diff)
> --strk;
>   ()   Free GIS & Flash consultant/developer
>   /\   http://strk.keybit.net/services.html
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
