[postgis-devel] [PostGIS] #904: PostGIS 2.0.0 stop testing on 8.3 and make 8.4 minimum
PostGIS trac at osgeo.org
Thu May 5 06:44:34 PDT 2011
 Reporter:  robe        |       Owner:  chodgson
     Type:  task        |      Status:  new
 Priority:  medium      |   Milestone:  PostGIS 2.0.0
Component:  management  |     Version:  trunk
 Keywords:  hudson      |
Comment(by robe):
 Chris,
 Hard to tell since we had fixed the regress issue with a hack.  However I
 plan to be introducing some code that is incompatible with 8.3 soon.  That
 should sure break any 8.3 still running around.
 What about the GEOS 3.3 change.  Though would be nice to still keep one
 running on 3.2 since I don't test on 3.2, but do on 3.3.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/904#comment:7>
