[postgis-devel] [PostGIS] #938: box2d of empty geom should be NULL
PostGIS trac at osgeo.org
Thu May 5 09:01:24 PDT 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 shouldn't it ?
 Currently (2.0):
 =# select gid, st_summary(the_geom), the_geom::box2d from cases;
 gid  |        st_summary        |   the_geom
  2416 | Polygon[ZM] with 1 rings | BOX(0 0,0 0)
       :    ring 0 has 0 points
Ticket URL: <http://trac.osgeo.org/postgis/ticket/938>
