[postgis-devel] [PostGIS] #940: Can't compile PostGIS against PostgreSQL 9.1 beta1
trac at osgeo.org
Thu May 5 19:22:40 PDT 2011
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
I think something has changed in maybe the aggregation logic of 9.1. I
was able to compile postgis against 9.1 alpha5 (saw I thought anyway).
Just switched to 9.1 beta1 and now I get this error.
-Ic:/projects/pg/pg91b1/include/POSTGR~1/server/port/win32 -c -o
lwgeom_accum.o lwgeom_accum.c
lwgeom_accum.c:306:54: macro "InitFunctionCallInfoData" requires 6
arguments, but only 5 given
lwgeom_accum.c: In function `PGISDirectFunctionCall1':
lwgeom_accum.c:306: error: `InitFunctionCallInfoData' undeclared (first
use in this function)
lwgeom_accum.c:306: error: (Each undeclared identifier is reported only
once
lwgeom_accum.c:306: error: for each function it appears in.)
make[1]: *** [lwgeom_accum.o] Error 1
Can someone else confirm who has PostgreSQL 9.1 beta 1 installed confirm
this is a real issue and not limited to my hacked MingW setup.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/940>
