[postgis-devel] [PostGIS] #941: ST_ModEdgeHeal : wrong response on non-existent edge
PostGIS trac at osgeo.org
Fri May 6 12:09:41 PDT 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
 try-ing this
 select topology.ST_ModEdgeHeal('topo_test',10000, 2);
 where 10.000 is a non-existent edge.
 I have this response:
  ERROR: TopoGeom 28 in layer 1 (topo_test.linee_topo.topo_geom) cannot be
 represented healing edges 10000 and 2
 I guess according to ISO the response should be
 "SQL/MM Spatial exception – non-existent edge"
 Same result for the third argument:
 select topology.ST_ModEdgeHeal('topo_test',1, 10000);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/941>
