[postgis-devel] [PostGIS] #946: more regression testing with GSERIALIZED_ON
PostGIS trac at osgeo.org
Mon May 9 04:38:06 PDT 2011
 Reporter:  robe      |       Owner:  robe
     Type:  task      |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 2.0.0
Component:  postgis   |     Version:  trunk
 Keywords:            |
 Or test after
 is turned GSERIALIZED_ON in gserialized.h and all relevant dead code is
 removed.
 - check again that all the regression failures are actually ones we're
 willing to accept (they are mostly about slight changes in the output of
 M-valued geometries in nested WKT, and Paul has decided they are "good"
 regressions)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/946>
