[postgis-devel] [PostGIS] #940: Can't compile PostGIS against PostgreSQL 9.1 beta1
PostGIS trac at osgeo.org
Wed May 11 19:04:23 PDT 2011
 Reporter:  robe     |       Owner:  robe
     Type:  defect   |      Status:  assigned
 Priority:  blocker  |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Changes (by robe):
  * owner:  pramsey => robe
  * status:  new => assigned
Comment:
 Mark,
 stl's patch works for me and all my mingw 8.4,9.0, 9.1 tested against vc++
 builds seem to pass regress (except the raster regress which I'll inspect
 in a bit to make sure they are real failures and not just line break
 issues and so forth).  If you are okay with this change, I'd like to
 commit my patched lwgeom_accum.c
 I'd like to release a new set of windows experimental builds with
 geos-3.3.0-rc1 and need this in before I can do that.
 Thanks,
 Regina
Ticket URL: <http://trac.osgeo.org/postgis/ticket/940#comment:11>
