[postgis-devel] [postgis-users] Infinite loop in st_intersects - because of incorrect data out of st_transform?
Sandro Santilli strk at keybit.net
Thu May 12 01:20:16 PDT 2011
On Thu, May 12, 2011 at 09:53:38AM +0200, Magnus Hagander wrote:
> On Tue, Mar 8, 2011 at 10:16, Magnus Hagander <magnus at hagander.net> wrote:
> > On Mon, Feb 28, 2011 at 16:35, Mark Cave-Ayland
> > <mark.cave-ayland at siriusit.co.uk> wrote:
> >> On 28/02/11 15:18, Magnus Hagander wrote:
> >>> Running the following query locks up postgis completely (in
> >>> geos::algorithm::RobustDeterminant):
> >>> SELECT st_intersects(somegeometry,
> >>> '0103000020E61000000100000005000000737979F3DDCC2CC0F92154F9E7534540000000000000F07F000000000000F07F8F806E993F7E55C0304B29FFEA8554400634E8D1DD424540B5FEE6A37FCD4540737979F3DDCC2CC0F92154F9E7534540'::geometry)
> >>> I believe this is because there are infinite values in that geometry:
> > Since nobody appears to be too interested in producing a quick fix in
> > geos, attached is a patch that puts in an *ugly* workaround in
> > PostGIS, that simply rejects the infinite values higher up in the
> > stack.
Please see http://trac.osgeo.org/geos/ticket/357
It was waiting for a testcase, as none helped reproducing
with 3.3.0rc1 so far.
I'll try with the data you give. It may need a second geometry to tango.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
