[postgis-devel] [PostGIS] #884: Unstable results with ST_Within, ST_Intersects
PostGIS trac at osgeo.org
Thu May 12 11:40:45 PDT 2011
 Reporter:  strk     |       Owner:  chodgson
     Type:  defect   |      Status:  assigned
 Priority:  high     |   Milestone:  PostGIS 1.5.3
Component:  postgis  |     Version:  1.5.X
 Keywords:           |
Changes (by chodgson):
  * owner:  pramsey => chodgson
  * status:  new => assigned
Comment:
 The logic used in point_in_multipolygon_rtree() was different that the
 logic in point_in_multipolygon(), and gave the wrong answer for the
 specific case of a point inside a polygon that is inside a hole of a
 larger polygon (island in a lake inside a larger area).
 I modified the multipolygon rtree cache structure to use the standard
 polygon order for multipolygons instead of the goofy list of all outer
 rings first followed by a list of all inner rings, which then make it
 possible to use the right logic in the rtree case.
 Committed fix for 1.5 branch in r7136.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/884#comment:17>
