[postgis-devel] [PostGIS] #944: typmod support for PostGIS geometry
PostGIS trac at osgeo.org
Fri May 13 01:29:29 PDT 2011
 Reporter:  robe         |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Comment(by robe):
 Mark,
 I think you missed my two main points
 1) If we expect people tomove to PostGIS 2.0, there current tables built
 with AddGeometryColumn should work as they did before.  It would be
 painful to have them alter their geometry columns to typmod.  With that
 said -- the postgresql catalog will be wrong for these geometries.
 2) For inheritance tables -- it is not unusual and I don't think bad
 practice to have each child have a separate geometry type (though it
 should have the same srid and dimension).  typmod simply doesn't work for
 this model.
 3) There are varying degrees -- e.g. I think for example Oracle doesn't
 mind POLYGON/MULTIPOLYGON coexisting.  Neither do ESRI Shapefiles.  When
 you have a polygon in must cases it is more efficient to keep it that way
 than wrapping it in a multi wrapper. typmod doesn't work for this either.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/944#comment:12>
