[postgis-devel] [PostGIS] #901: [raster] ST_AsGDALRaster and the helper functions ST_getGDALDrivers and ST_srtext
PostGIS trac at osgeo.org
Mon May 16 23:01:08 PDT 2011
ST_srtext
  Reporter:  dustymugs       |       Owner:  dustymugs
      Type:  task            |      Status:  reopened
  Priority:  medium          |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:                  |    Keywords:  history
Comment(by robe):
 Well on the bright-side I can compile the latest stable gdal 1.8.0.
 Swapping out didn't help though so you are probably right.. Anyrate in the
 middle of recompiling PostGIS, though I doubt that will help.
 I wonder if its the same issue I have on windows as described here: #748
 To overcome, I just used Mark's hack of remarking out the nls_build line
 in the loader/Makefile.in
 Though don't see a similar setting in raster.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/901#comment:19>
