[postgis-devel] [PostGIS] #954: [raster] ST_AsTiff syntax error
PostGIS trac at osgeo.org
Tue May 17 08:08:31 PDT 2011
  Reporter:  strk            |       Owner:  dustymugs
      Type:  defect          |      Status:  closed
  Priority:  blocker         |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:  fixed           |    Keywords:
Changes (by strk):
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 r7171 does fix the syntax error, thanks
Ticket URL: <http://trac.osgeo.org/postgis/ticket/954#comment:7>
