[postgis-devel] Should we start using default args now?
Paragon Corporation lr at pcorp.us
Tue May 17 10:41:29 PDT 2011
I like that.  Though we should start with Bborie's first (which doesn't
require drop anything since they are so new)
Many of the raster functions have 4 or 5 protos per function.
So Bborie added about 10 (hmm maybe more but that's as high as I can count)
new functions each of which has anywhere from 2-10 permutations. -- to add
up to a lot.
For example:
http://www.postgis.org/documentation/manual-svn/RT_ST_AsPNG.html
Great functions by the way :)
So I've been hesitant to document the ST_AsTiff, ST_AsJPEG and all the
analytics if we are going to go default args.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Tuesday, May 17, 2011 1:20 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Should we start using default args now?
We can include DROP IF EXISTS at the front of the upgrade scripts (already
do that do some extent) to clean out non-defaulted pre-existing functions.
P.
On Mon, May 16, 2011 at 11:04 PM, Paragon Corporation <lr at pcorp.us> wrote:
> No CREATE OR REPLACE would not  replace them.  We would have to drop them.
> I was thinking about just new functions like the 100 some odd Bborie
> just loaded on us :)
> Sandro Santilli
> Sent: Tuesday, May 17, 2011 2:01 AM
> On Tue, May 17, 2011 at 01:01:13AM -0400, Paragon Corporation wrote:
>> Now that Bborie has unleashed his load of functions; I'm not
>> complaining, I did ask for it :)
>> I was wondering if maybe we should start using default arguments at
>> least for raster.  Now that our minimum is 8.4 for PostGIS 2.0, this
>> is now an option.  Does it make sense?
> If 8.4 supports them, I'm for it. Surely for new functions.
> Old functions might need more verifications (does CREATE OR REPLACE
> replace them ?).
> --strk;
>  ()   Free GIS & Flash consultant/developer
>  /\   http://strk.keybit.net/services.html
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
