[postgis-devel] knn test - first result
Sandro Santilli strk at keybit.net
Fri May 20 01:16:36 PDT 2011
On Fri, May 20, 2011 at 01:45:31AM -0400, maplabs at light42.com wrote:
> well, perhaps I have missed something..
> however, on a fresh debian6 vm, GEOS trunk, postgis trunk, postgresql 9.1b1 built from source
> I loaded some POINT ( with GIST index unchanged from the dump coming from 8.4 )
>  and a proximity search "just worked".. 100x faster.. what needs to be done ?
Try postgresql-8.4 with the _same_ GEOS and postgis versions, and the
same input data (loaded in the same order and with same index in place).
Also, make sure it is 32bit as your 9.1b is...
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
