[postgis-devel] [PostGIS] #958: [raster] Regress test failures on 32 bit
PostGIS trac at osgeo.org
Fri May 20 06:42:39 PDT 2011
 Reporter:  strk            |       Owner:  jorgearevalo
     Type:  defect          |      Status:  assigned
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by jorgearevalo):
 Ok, one missed PG_FREE_IF_COPY call in line 2034 was causing the memory
 issue. Now I've problems with regress tests rt_asgdalraster, rt_asjpeg and
 rt_aspng. Working of them. Attached the diff files.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/958#comment:17>
