[postgis-devel] [postgis-users] how to keep geometry_columns in sync wit tablesand views (and new PostGIS 2.0 plans)
Stephen Frost sfrost at snowman.net
Fri May 20 08:34:23 PDT 2011
All,
* Sandro Santilli (strk at keybit.net) wrote:
> On Fri, May 20, 2011 at 03:15:26AM -0400, Paragon Corporation wrote:
> > So that is why I was proposing a hybrid -- geometry_columns  -- so new
> > PostGIS can work with older tools
Having a hybrid may work for backwards-compatibility reasons, but we
should have a solution which doesn't require such an ugly hack for new
code/systems/etc.
> > Though I suppose that may be more confusing than it's worth and there is the
> > case of views
Regarding views, what I would actually suggest is that we allow users a
way to tell update the typmod for the view definition directly in the
catalog rather than suggesting that they use a seperate table as an
override.
We could do this pretty easily using a function which the user would
call (instead of adding to or updating a table) which would update the
catalog definition for the view.  We could also try to see if there's a
way to support doing this through 'alter view'.
> My opinion is starting to form on this and currently is closer to
> "maintain a real table".
This might be acceptable as a backwards-compatibility mode, but I think
we need a solution which doesn't depend on overriding values that are in
the catalog.
	Thanks,
		Stephen
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110520/52b0285e/attachment.sig>
