[postgis-devel] [PostGIS] #958: [raster] Regress test failures on 32 bit
PostGIS trac at osgeo.org
Fri May 20 05:05:02 PDT 2011
 Reporter:  strk            |       Owner:  jorgearevalo
     Type:  defect          |      Status:  assigned
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by strk):
 That call checks a run of perl ??
 Even if you drop the perl part, you're testin the client, not the server.
 Checking the server requires running the backend in single-user mode and
 passing it the offending query.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/958#comment:15>
