[postgis-devel] [PostGIS] #963: Stop downloading DTDs
PostGIS trac at osgeo.org
Fri May 20 03:32:47 PDT 2011
 Reporter:  robe        |       Owner:  chodgson
     Type:  defect      |      Status:  new
 Priority:  medium      |   Milestone:  PostGIS 2.0.0
Component:  management  |     Version:  trunk
 Keywords:              |
Comment(by mcayland):
 We definitely do not want to be including the DTDs as part of the tarball.
 The way to think about it is that xsltproc checks a local cache for the
 DTD first, and only then if it can't find it does it go and download from
 the origin.
 I don't know what OS the build host is running, but on Debian it looks as
 if it's just a case of "aptitude install docbook-mathml". There will
 definitely be similar packages around for Fedora/CentOS and other OS too.
 Installing the relevant packages on the build host is definitely the right
 fix here.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/963#comment:8>
