[postgis-devel] [PostGIS] #958: [raster] Regress test failures on 32 bit
PostGIS trac at osgeo.org
Fri May 20 06:56:51 PDT 2011
 Reporter:  strk            |       Owner:  jorgearevalo
     Type:  defect          |      Status:  assigned
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by jorgearevalo):
 I'm getting the regress results of pgis_reg_27067 in a 32b Ubuntu 9.10
 machine with r7202. No memory leaks neither segfaults. Only the failures
 of ticket #957.
 Could you please give it a try?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/958#comment:20>
