[postgis-devel] [PostGIS] #977: ValidateTopology: don't skip the Universal Face
PostGIS trac at osgeo.org
Sun May 22 13:23:28 PDT 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
 testing the ValidateTopology I see it don't skip the UniverseFace.
 The bug is in this code:
         -- Now create a temporary table to construct all face geometries
         -- for checking their consistency
         EXECUTE 'CREATE TEMP TABLE face_check ON COMMIT DROP AS '
           || 'SELECT face_id, topology.ST_GetFaceGeometry('
           || quote_literal(toponame) || ', face_id) as geom, mbr FROM '
           || quote_ident(toponame) || '.face';
 It don't skip the UniverseFace (face_id=0) in the face table. The
 UniverseFace has geom=NULL so the GetFaceGeometry give an ISO sql/mm error
 I guess the code can be patched with this :
         || ' WHERE face_id<>0;';
 A attach the patch to this ticket.
 Also I change the Validate Regress Test filling the
 MBR geom field of the Face table that I notice was empty.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/977>
