[postgis-devel] [PostGIS] #965: ST_AddIsoNode allows adding non-isolated nodes (nodes with containing_face=null)
PostGIS trac at osgeo.org
Mon May 23 01:50:55 PDT 2011
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by aperi2007):
 I agree with this solution.
 Because reading the specs, other funzions work like this.
 For example, the ST_GetFaceGeometry.
 From ISO specs:
 Allow to pass the 0 value but intercept it giving an
 "Error - sql/mm spatial exception - universal face has no geometry".
 Always the ST_GetFaceGeometry from ISO specs:
 with a parameter idface = NULL
 shuold intercept it giving an error:
 "Error - sql/mm spatial exception - null argument".
 So I guess is correct to think to idface=0 as the value for an
 UniversalFace, and don't use the NULL value as UniversalFace.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/965#comment:1>
