[postgis-devel] [PostGIS] #965: ST_AddIsoNode allows adding non-isolated nodes (nodes with containing_face=null)
PostGIS trac at osgeo.org
Mon May 23 02:09:15 PDT 2011
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by aperi2007):
 Yes.
 Also I guess we could apply a real simplification to workflow because to
 do this test implicitly we find the face that really contain it :)
 So even if the user pass idface=0, if the system see that the face is not
 the UniverseFace (id=0) but instead the (for example) idface=7. It should
 put that value instead of 0 instead of raise an error.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/965#comment:3>
