[postgis-devel] [PostGIS] #973: ST_GetFaceGeometry - don't intercept the UniverseFace
PostGIS trac at osgeo.org
Mon May 23 14:29:23 PDT 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
Comment(by aperi2007):
 I would report that the ST_GetFaceGeometry actually don't intercept the
 case of Universe face so calling the ST_GetFaceGeometry
 topology.ST_GetFaceGeometry('topo_name', 0);
 with the UniverseFace will raise an error in other part of code because it
 return a record with NULL value.
 It should be add a check for tha case "aface=0" the give the right
 exception.
 If Ok , I could produce a patch for this.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/973#comment:2>
