[postgis-devel] [PostGIS] #980: topology Regress failures on 9.1 beta - array_lower(topology.topoelementarray, integer) does not exist
PostGIS trac at osgeo.org
Mon May 23 22:54:55 PDT 2011
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 strk,
 Sorry haven't been regress testing topology since the raster regress issue
 I am having interrupted this so had to create a special regress line to
 test topology.
 Anyrate I still have to test on 9.0, but I get a lot of failures on 9.1.
 Spot checking some -- they all look like same error
 psql:load_features.sql:68: ERROR:  function
 So I guess maybe you need to put in an explicit cast to cast
 topoelementarray to a regular array.  Hmm could be a bug in 9.1 though. I
 don't see why this should be necessary.
 I've zipped up my regress log
Ticket URL: <https://trac.osgeo.org/postgis/ticket/980>
