[postgis-devel] [PostGIS] #973: ST_GetFaceGeometry - don't intercept the UniverseFace
PostGIS trac at osgeo.org
Tue May 24 00:51:02 PDT 2011
 Reporter:  aperi2007  |       Owner:  strk
     Type:  defect     |      Status:  assigned
 Priority:  medium     |   Milestone:  PostGIS 2.0.0
Component:  topology   |     Version:  trunk
 Keywords:             |
Comment(by strk):
 The specs say that ST_GetFaceGeometry should use ST_GetFaceEdges to
 construct the face, and the description of ST_GetFaceEdges does not say
 anything special about the universal face.
 I don't see NULL being returned, but a multipolygon, where each "hole" in
 the universal face is represented as a polygon. This is equivalent to the
 union of all faces.
 If not backed up by specs, do we still want to throw an exception here ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/973#comment:4>
