[postgis-devel] [PostGIS] #985: [raster] ST_Count
PostGIS trac at osgeo.org
Tue May 24 10:51:48 PDT 2011
 Reporter:  dustymugs       |       Owner:  pracine
     Type:  task            |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS Raster Future
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 This function calls ST_SummaryStats and only returns the count from that
 function.
 1. ST_Count(rast raster, nband int, hasnodata boolean) -> integer
     returns the count as an integer
     nband: index of band
     hasnodata: if FALSE, any pixel who's value is nodata is ignored
 ST_Count(rast, 1, FALSE)
 2. ST_Count(rast raster, nband int) -> integer
     assumes hasnodata = TRUE
 ST_Count(rast, 2)
 3. ST_Count(rast raster, hasnodata boolean) -> integer
     assumes nband = 1
 ST_Count(rast, TRUE)
 4. ST_Count(rast raster) -> integer
     assumes nband = 1 and hasnodata = TRUE
 ST_Count(rast)
 The set of ST_ApproxCount functions are:
 1. ST_ApproxCount(rast raster, nband int, hasnodata boolean,
 sample_percent double precision) -> integer
     sample_percent: a value between 0 and 1 indicating the percentage of
 the raster band's pixels to consider
 ST_ApproxCount(rast, 3, FALSE, 0.1)
 ST_ApproxCount(rast, 1, TRUE, 0.5)
 2. ST_ApproxCount(rast raster, nband int, sample_percent double precision)
 -> integer
     assumes that nband = 1
 ST_ApproxCount(rast, 2 0.01)
 ST_ApproxCount(rast, 4, 0.025)
 3. ST_ApproxCount(rast raster, hasnodata boolean, sample_percent double
 ST_ApproxCount(rast, FALSE, 0.01)
 ST_ApproxCount(rast, TRUE, 0.025)
 4. ST_ApproxCount(rast raster, sample_percent double precision) -> integer
     assumes that nband = 1 and hasnodata = TRUE
 ST_ApproxCount(rast, 0.25)
 5. ST_ApproxCount(rast raster) -> integer
     assumes that nband = 1, hasnodata = TRUE and sample_percent = 0.1
 ST_ApproxCount(rast)
 The following functions are provided for coverage tables.
 1. ST_Count(rastertable text, rastercolumn text, nband int, hasnodata
 boolean) -> integer
     rastertable: name of table with raster column
     rastercolumn: name of column of data type raster
 ST_Count('tmax_2010', 'rast', 1, FALSE)
 ST_Count('precip_2011', 'rast', 1, TRUE)
 2. ST_Count(rastertable text, rastercolumn text, nband int) -> integer
     hasnodata = TRUE
 ST_Count('tmax_2010', 'rast', 1)
 3. ST_Count(rastertable text, rastercolumn text, hasnodata boolean) ->
 integer
     nband = 1
 ST_Count('precip_2011', 'rast', TRUE)
 4. ST_Count(rastertable text, rastercolumn text) -> integer
 ST_Count('tmin_2009', 'rast')
 Variations for ST_ApproxCount are:
 1. ST_ApproxCount(rastertable text, rastercolumn text, nband int,
 hasnodata boolean, sample_percent double precision) -> integer
 ST_ApproxCount('tmax_2010', 'rast', 1, FALSE, 0.5)
 ST_ApproxCount('precip_2011', 'rast', 1, TRUE, 0.2)
 2. ST_ApproxCount(rastertable text, rastercolumn text, nband int,
     hasnodata = TRUE
 ST_ApproxCount('tmax_2010', 'rast', 1, 0.5)
 ST_ApproxCount('precip_2011', 'rast', 1, 0.2)
 3. ST_ApproxCount(rastertable text, rastercolumn text, hasnodata boolean,
     nband = 1
 ST_ApproxCount('tmax_2010', 'rast', FALSE, 0.5)
 ST_ApproxCount('precip_2011', 'rast', TRUE, 0.2)
 4. ST_ApproxCount(rastertable text, rastercolumn text, sample_percent
 ST_ApproxCount('tmax_2010', 'rast', 0.5)
 ST_ApproxCount('precip_2011', 'rast', 0.2)
 5. ST_ApproxCount(rastertable text, rastercolumn text) -> integer
 ST_ApproxCount('tmax_2010', 'rast')
 ST_ApproxCount('precip_2011', 'rast')
Ticket URL: <http://trac.osgeo.org/postgis/ticket/985>
