[postgis-devel] [PostGIS] #986: [raster] ST_Sum
PostGIS trac at osgeo.org
Tue May 24 10:53:57 PDT 2011
 Reporter:  dustymugs       |       Owner:  pracine
     Type:  task            |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS Raster Future
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 This function calls ST_SummaryStats and only returns the sum from that
 function.
 1. ST_Sum(rast raster, nband int, hasnodata boolean) -> double precision
     returns the sum as an integer
     nband: index of band
     hasnodata: if FALSE, any pixel who's value is nodata is ignored
 ST_Sum(rast, 1, FALSE)
 2. ST_Sum(rast raster, nband int) -> double precision
     assumes hasnodata = TRUE
 ST_Sum(rast, 2)
 3. ST_Sum(rast raster, hasnodata boolean) -> double precision
     assumes nband = 1
 ST_Sum(rast, TRUE)
 4. ST_Sum(rast raster) -> double precision
     assumes nband = 1 and hasnodata = TRUE
 ST_Sum(rast)
 The set of ST_ApproxSum functions are:
 1. ST_ApproxSum(rast raster, nband int, hasnodata boolean, sample_percent
 double precision) -> double precision
     sample_percent: a value between 0 and 1 indicating the percentage of
 the raster band's pixels to consider
 ST_ApproxSum(rast, 3, FALSE, 0.1)
 ST_ApproxSum(rast, 1, TRUE, 0.5)
 2. ST_ApproxSum(rast raster, nband int, sample_percent double precision)
 -> double precision
     assumes that nband = 1
 ST_ApproxSum(rast, 2 0.01)
 ST_ApproxSum(rast, 4, 0.025)
 3. ST_ApproxSum(rast raster, hasnodata boolean, sample_percent double
 ST_ApproxSum(rast, FALSE, 0.01)
 ST_ApproxSum(rast, TRUE, 0.025)
 4. ST_ApproxSum(rast raster, sample_percent double precision) -> double
 precision
     assumes that nband = 1 and hasnodata = TRUE
 ST_ApproxSum(rast, 0.25)
 5. ST_ApproxSum(rast raster) -> double precision
     assumes that nband = 1, hasnodata = TRUE and sample_percent = 0.1
 ST_ApproxSum(rast)
 The following functions are provided for coverage tables.
 1. ST_Sum(rastertable text, rastercolumn text, nband int, hasnodata
     rastertable: name of table with raster column
     rastercolumn: name of column of data type raster
 ST_Sum('tmax_2010', 'rast', 1, FALSE)
 ST_Sum('precip_2011', 'rast', 1, TRUE)
 2. ST_Sum(rastertable text, rastercolumn text, nband int) -> double
 precision
     hasnodata = TRUE
 ST_Sum('tmax_2010', 'rast', 1)
 3. ST_Sum(rastertable text, rastercolumn text, hasnodata boolean) ->
 double precision
     nband = 1
 ST_Sum('precip_2011', 'rast', TRUE)
 4. ST_Sum(rastertable text, rastercolumn text) -> double precision
 ST_Sum('tmin_2009', 'rast')
 Variations for ST_ApproxSum are:
 1. ST_ApproxSum(rastertable text, rastercolumn text, nband int, hasnodata
 boolean, sample_percent double precision) -> double precision
 ST_ApproxSum('tmax_2010', 'rast', 1, FALSE, 0.5)
 ST_ApproxSum('precip_2011', 'rast', 1, TRUE, 0.2)
 2. ST_ApproxSum(rastertable text, rastercolumn text, nband int,
     hasnodata = TRUE
 ST_ApproxSum('tmax_2010', 'rast', 1, 0.5)
 ST_ApproxSum('precip_2011', 'rast', 1, 0.2)
 3. ST_ApproxSum(rastertable text, rastercolumn text, hasnodata boolean,
     nband = 1
 ST_ApproxSum('tmax_2010', 'rast', FALSE, 0.5)
 ST_ApproxSum('precip_2011', 'rast', TRUE, 0.2)
 4. ST_ApproxSum(rastertable text, rastercolumn text, sample_percent double
 ST_ApproxSum('tmax_2010', 'rast', 0.5)
 ST_ApproxSum('precip_2011', 'rast', 0.2)
 5. ST_ApproxSum(rastertable text, rastercolumn text) -> double precision
 ST_ApproxSum('tmax_2010', 'rast')
 ST_ApproxSum('precip_2011', 'rast')
Ticket URL: <http://trac.osgeo.org/postgis/ticket/986>
