[postgis-devel] Fwd: [MetaCRS] Inf in projection results
Paul Ramsey pramsey at opengeo.org
Tue May 24 13:03:21 PDT 2011
---------- Forwarded message ----------
From: Martin Desruisseaux <martin.desruisseaux at geomatys.fr>
Date: Tue, May 24, 2011 at 11:34 AM
Subject: Re: [MetaCRS] Inf in projection results
To: metacrs at lists.osgeo.org
Le 24/05/11 19:36, Paul Ramsey a écrit :
> And following on with a non-projection-related query: if you as a
> geometry processing routine got handed a geometry with Inf
> coordinates, what would you do? Give up? Coerce them into something
> else?
I would suggest to keep the infinite values. IEEE arithmetic usually
do the right thing with infinities (x/Inf = 0 if x!=Inf, etc.), and
Java Math functions are properly defined (atan(Inf) = 90°, etc.).
In Geotoolkit.org, we have allowed Map Projection to returns infinite
values (e.g. 90°N in a Mercator projection = Infinity, and ensuring
that the conversion back to EPSG:4326 give 90°N). In my point of view
this actually make the handling of geometries easier. By removing as
much special cases of the like "if (x < threshold)" as possible (which
were used in order to avoid divisions by zero in the legacy GeoTools
referencing code), users have reported that the reprojections were
smoother.
Regards,
   Martin
MetaCRS mailing list
MetaCRS at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/metacrs
