[postgis-devel] In-place upgrade to 2.0
Paul Ramsey pramsey at opengeo.org
Tue May 24 13:08:12 PDT 2011
Doesn't look like its useful. We need something like cast, that will
apply a function to the input to it goes in one way and comes out
another. Another possibility would be to see if the binary signature
of serialized_form is sufficiently distinct from gserialized that we
can just transparently notice which form we're receiving and go from
there in the deserialization function. Mmmm. Probably not, there's too
many pieces of code that want to only partially deserialize for
performance reasons and expect a certain disk layout.
P.
On Tue, May 24, 2011 at 1:05 PM, Paul Ramsey <pramsey at opengeo.org> wrote:
> I DID NOT KNOW THAT!
> That's really excellent, and boy I wish I knew what file I should be
> reading to know all these new features... what file should I be
> reading?
> I'll look at this and see if it's useful for our problem.
> P.
> On Tue, May 24, 2011 at 12:04 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> Yes you are correct -- it will bulk.  You have to drop the views currently
>> if you change any column used in a view.  The ability for a view to
>> automagically rebuild themselves has been on the plate for as far back as I
>> can remember and I don't think its funded yet and it drives Leo crazy :).
>> However for 9.1 users, 9.1 supports ALTER TYPE  so you could just change the
>> TYPE underneath the hood so even if uses use views, it should work to just
>> ALTER the TYPE.  But of course you probably already new that :)
>> Thanks,
>> Regina
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net
>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
>> Ramsey
>> Sent: Tuesday, May 24, 2011 11:30 AM
>> To: PostGIS Development Discussion
>> Subject: Re: [postgis-devel] In-place upgrade to 2.0
>> yes, my scheme was going to be to two-step by first creating GEOMETRY2, then
>> altering all the columns to that (by maintaining an lwgeom handler to do the
>> cast from serialized_form to gserialized), then creating GEOMETRY and
>> altering all the columns to that. Which would work fine for data-only
>> databases, but installations with more complex constructions (views,
>> triggers) expecting 'geometry' input arguments might balk if I alter their
>> column types underneath them.
>> P.
>> On Mon, May 23, 2011 at 1:49 AM, Mark Cave-Ayland
>> <mark.cave-ayland at siriusit.co.uk> wrote:
>>> On 21/05/11 10:56, Paul Ramsey wrote:
>>>> The mechanism is the same for everyone, the 9.1 users just get it
>>>> "automagically" with a SQL command and everyone else has to (quell
>>>> horror!) run a .sql file.
>>>> Though now that I think about it in the clear light of early morning
>>>> there's lots of ways my scheme will fail, so perhaps not.
>>> I thought that in-place upgrade only works if the binary formats are
>>> unchanged? So if we change LWGEOM -> G_GEOMETRY then this isn't going
>>> to work. Or does the extension upgrade execute an ALTER COLUMN
>>> statement to rebuild the column anyway?
>>> ATB,
>>> Mark.
>>> Mark Cave-Ayland - Senior Technical Architect PostgreSQL - PostGIS
>>> Sirius Corporation plc - control through freedom
>>> http://www.siriusit.co.uk
>>> t: +44 870 608 0063
>>> Sirius Labs: http://www.siriusit.co.uk/labs
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
