[postgis-devel] [PostGIS] #957: [raster] rt_asgdalraster regress test fails
PostGIS trac at osgeo.org
Wed May 25 11:25:56 PDT 2011
  Reporter:  strk            |       Owner:  dustymugs
      Type:  defect          |      Status:  closed
  Priority:  medium          |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:  fixed           |    Keywords:
Comment(by dustymugs):
 I don't know if the problems I had are the same but I was experiencing a
 similar scenario with all the raster regression errors.  In looking at the
 outputted regress_log, I found that the loading of rtpostgis.sql failed on
 the last ST_MapAlgebra function (~ line 1645).  Everything worked fine
 once I commented out that line.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/957#comment:27>
