[postgis-devel] [PostGIS] #985: [raster] ST_Count
PostGIS trac at osgeo.org
Fri May 27 11:49:15 PDT 2011
  Reporter:  dustymugs       |       Owner:  dustymugs
      Type:  task            |      Status:  reopened
  Priority:  medium          |   Milestone:  PostGIS 2.0.0
 Component:  postgis raster  |     Version:  trunk
Resolution:                  |    Keywords:  history
Comment(by pracine):
 > I do like "include_nodata" as the argument name is easy to understand in
 the context of the function.
 I would like "include_nodata" too if it would also mean something in the
 context of other functions like ST_Intersects(). But no...
 To make it brief: "hasdodata = TRUE means the raster HAS nodata values, so
 the function MUST DEAL with those nodata values in the proper way (ignore
 them). If hasdodata is FALSE, is should consider nodata values as any
 normal values."
 Up to now this is still the most simple way i have found to specify this
 which work everywhere.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/985#comment:7>
