[postgis-devel] [PostGIS] #963: Stop downloading DTDs
PostGIS trac at osgeo.org
Sat May 28 08:58:37 PDT 2011
 Reporter:  robe        |       Owner:  chodgson
     Type:  defect      |      Status:  new
 Priority:  medium      |   Milestone:  PostGIS 2.0.0
Component:  management  |     Version:  trunk
 Keywords:              |
Comment(by robe):
 Chris,
 I think we are still downloading stuff, though not mathml anymore so
 perhaps you fixed that. I just did a commit that had no documentation
 changes and it failed on documentation build.
 PostGIS-trunk-build #2340 (r7281)
 Thru this complaint:
 make[1]: Entering directory `<http://office.refractions.net:1500/job
 /PostGIS-trunk-build/ws/build/doc/html/image_src'>
 make[1]: Nothing to be done for `images'.
 make[1]: Leaving directory `<http://office.refractions.net:1500/job
 Build the listings...
 http://www.oasis-open.org/docbook/xml/4.5/dbpoolx.mod:1: parser error :
 Content error in the external subset
 HTTP/1.1 200 OK
 HTTP/1.1 200 OK
 unable to parse <http://office.refractions.net:1500/job/PostGIS-trunk-
 build/ws/build/doc/postgis-out.xml>
 Error: xsltproc failed
 make: *** [postgis-2.0.0SVN.pdf] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/963#comment:12>
