[postgis-devel] lwgeom->bbox
Nicklas Avén nicklas.aven at jordogskog.no
Tue Nov 1 15:07:32 PDT 2011
Sorry, forget it.
I see that was exactly what you meant Paul. You remembered perfectly
right.
/Nicklas
On Tue, 2011-11-01 at 23:01 +0100, Nicklas Avén wrote:
> Hallo
> > Well, for the objects we're not currently already computing it
> > (points) that's not a big deal, but I can see how subcomponents might
> > be an issue. But I recall that Nik had to fight with this a bit in his
> > work since he needed to compute boxes before he could get started with
> > his distance routines...
> Yes, but that was at sub geometry level. So I needed bboxes of every sub
> geometry in the multi geometry cases.
