[postgis-devel] [PostGIS] #1206: ST_Node
PostGIS trac at osgeo.org
Fri Nov 4 11:50:10 PDT 2011
#1206: ST_Node
  Reporter:  strk     |       Owner:  strk
      Type:  defect   |      Status:  closed
  Priority:  medium   |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:  history
Changes (by strk):
  * keywords:  => history
  * status:  assigned => closed
  * resolution:  => fixed
Comment:
 Ok, this is implemented, regress-tested and documented as of r8094.
 Would be nice to add examples in the dox but the XML is too complex for me
 Here's a nice example:
 => select st_asewkt(st_node('LINESTRING(0 0 0, 10 10 10, 0 10 5, 10 0
 3)'));
  MULTILINESTRING((0 0 0,5 5 4.5),(5 5 4.5,10 10 10,0 10 5,5 5 4.5),(5 5
 4.5,10 0 3))
 Mind you: it requires GEOS-3.3.2dev due to
 http://trac.osgeo.org/geos/ticket/482
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1206#comment:7>
