[postgis-devel] [PostGIS] #1265: no ID for constraint linkend: PostGIS_Geometry_DumpFunctions
PostGIS trac at osgeo.org
Fri Nov 4 13:55:37 PDT 2011
 Reporter:  strk           |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.0
Component:  documentation  |     Version:  trunk
 Keywords:                 |
Comment(by robe):
 That is an autogenerated section.  Do you have a postgis_aggs_mm.xml file
 being generated.  Wonder if that is not being built before the other
 parts.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1265#comment:1>
