[postgis-devel] [PostGIS] #1267: Add manuel height/weight support to ST_Resample
PostGIS trac at osgeo.org
Fri Nov 4 16:42:22 PDT 2011
 Reporter:  serveralex      |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
 Either add support to specify these parameters manually or use these
 values directly from the reference raster (which makes the semantics far
 more clear). The "normal" user would expect that the ST_Resample result
 raster would have the exact same parameters as the reference raster, which
 isn't the case currently.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1267>
