[postgis-devel] [PostGIS] #1252: SRID appearing in ST_AsText for particular multipolygon
Sandro Santilli strk at keybit.net
Sat Nov 5 11:47:10 PDT 2011
>  Reporter:  robe     |       Owner:  pramsey
>      Type:  defect   |      Status:  new
>  Priority:  medium   |   Milestone:  PostGIS 1.5.4
> Component:  postgis  |     Version:  1.5.X
>  Keywords:           |
> Comment(by robe):
>  strk - FYI - just retired again on  a1.5.3 database running the latest
>  3.3.2dev and I still get the same weird behavior.  Now I fear it might be
>  a windows only bug.
>  Do you have a 1.5 install?  I haven't compiled 1.5.4svn to see if the
>  problem is still there I'll try to do that later.
>  Make sure you are testing with the script I attached to this ticket
>  http://trac.osgeo.org/postgis/attachment/ticket/1252/weird_poly.sql
Robe, are you saying you can reproduce the bug with the attached script ?
I surely can't, and I'm surprised you can.
I'm testing with 1.5 branch.
--strk;
  ()   Free GIS & Flash consultant/developer
  /\   http://strk.keybit.net/services.html
