[postgis-devel] [PostGIS] #1252: SRID appearing in ST_AsText for particular multipolygon
PostGIS trac at osgeo.org
Sat Nov 5 17:48:20 PDT 2011
 Reporter:  robe             |       Owner:  pramsey
     Type:  defect           |      Status:  new
 Priority:  medium           |   Milestone:  PostGIS 1.5.4
Component:  postgis          |     Version:  1.5.X
 Keywords:  windows, 64-bit  |
Comment(by robe):
 forgot to add on the windows 2008 32-bit I just tested I also tested with
 GEOS 3.2.2 (which it had already installed), GEOS 3.3.2dev.  All worked
 fine with 1.5.2 and 1.5.4. I'll assume 1.5.3 was fine too but didn't test
 that since my 64-bit testers failed on all 1.5 versions tested and all
 GEOS 3.3s tested.  Note I was also using the same builds I had compiled on
 my 64-bit windows 7.  So I think that rules out build as culprit.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1252#comment:13>
