[postgis-devel] [PostGIS] #1271: ST_Line_Locate_Point inaccurate closest point
PostGIS trac at osgeo.org
Tue Nov 8 00:45:35 PST 2011
 Reporter:  strk     |       Owner:  strk
     Type:  defect   |      Status:  assigned
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 Oh.. wonder.
 =# SELECT 'line_locate_point_1',
 ST_line_locate_point('LINESTRING(709243.393033887
 163969.752725768,708943.240904444 163974.593889146,708675.634380651
 163981.832927298)', 'POINT(705780 15883)');
 NOTICE:  t:3, pa->npoints:3, end:(708943 163975)
 Indeed "end" is _not_ the last point, but the second-last.
 It's actually the endpoint of the first segment. I guess I should be using
 "seg" rather than "t"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1271#comment:4>
