[postgis-devel] [PostGIS] #1273: ST_Equals( mypoint, postgis_addbbox(mypoint) ) = FALSE
PostGIS trac at osgeo.org
Tue Nov 8 07:08:47 PST 2011
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  high     |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 For the record: this case came out from an attempt to convert a set of
 polygons into a topology using topology.ST_CreateTopoGeom. There is _no_
 call to postgis_addbbox() in there, so some other function is also
 producing a point-with-a-box, which in turn makes ST_Equals fail. That
 other function would probably be another bug.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1273#comment:2>
