[postgis-devel] Float vs Double Box
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Thu Nov 10 08:05:03 PST 2011
On 09/11/11 20:09, Nicklas Avén wrote:
> Another aspect of double vs float is that the float boxes might give
> wrong ordering from knn-gist.
> In other cases we can round the float box up to a slightly bigger box,
> but in the ordering case that will not help.
> That is why we get different answer from native Postgresql knn and
> PostGIS as I discussed the other week, because Postgresql is not using
> the bbox but the point itself. I'm I right or have I misunderstood?
Yes indeed, this was the reason I was suggesting that we should be using
doubles for everything - coordinates, internal BBOXes and the index.
Otherwise we find ourselves in situations where queries can return
different results depending upon whether either a sequential scan or an
index scan is used, or whether the geometry has an internal BBOX or not :(
Now obviously there is a penalty here in terms of index space but what
we need to ask ourselves is what do we consider to be important? A query
that takes less disk I/O but can semi-randomly return an incorrect
answer, or a query that takes more disk I/O but consistently returns the
correct answer? Perhaps in the past this wasn't so important, but now we
are looking at using indices to accelerate more queries (such as
KNN-GiST) it's going to become more of an issue moving forward.
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
