[postgis-devel] [PostGIS] #1274: ST_CreateTopoGeo failed
PostGIS trac at osgeo.org
Fri Nov 11 04:41:28 PST 2011
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by strk):
 GetNodeByPoint returning 0 means no point found, which means a point added
 with ST_AddIsoNode isn't found later. Probably still suffering from float
 vs. double but I'll need closer inspection
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1274#comment:2>
