[postgis-devel] [PostGIS] #1283: ST_MapAlgebraFct 2 band version function proto looks wrong
PostGIS trac at osgeo.org
Fri Nov 11 15:16:26 PST 2011
 Reporter:  robe            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 Okay I think we have a small little problem here, which may or may not
 related.  you are right I'm not seeing this in the rtpostgis.sql.
 But how would one distinguish between this:
 CREATE OR REPLACE FUNCTION st_mapalgebrafct(
         rast1 raster, band1 integer,
         rast2 raster, band2 integer,
         userfunction regprocedure,
         pixeltype text DEFAULT NULL, extenttype text DEFAULT
 'INTERSECTION',
         VARIADIC userargs text[] DEFAULT NULL
 and
 After all in the first - those extra texts could easily fall into VARIADIC
 loop since they are optional.  I think your first one the arguments should
 not  have defaults.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1283#comment:3>
