[postgis-devel] [PostGIS] #1284: ST_CreateTopoGeo: non-existent node
PostGIS trac at osgeo.org
Fri Nov 11 23:10:06 PST 2011
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 An input derived from sample dataset in #1274 produces a "non-existent
 node" exception when feed to ST_CreateTopoGeo.
 Robustness issues moving from GEOS to PostGIS, whoa ! :)
 Here's the reduced version of the offending input, at the max reduction I
 was able to perform so far.
 MULTILINESTRING(
  832709.937 816560.25,
  832705.813 816470.25,
  832661.937 816561.875
  832705.812 816470.25,
  832661.938 816561.875,
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1284>
