[postgis-devel] [PostGIS] #1288: Update Best practices
PostGIS trac at osgeo.org
Sat Nov 12 07:52:38 PST 2011
 Reporter:  robe           |       Owner:  robe
     Type:  task           |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.0
Component:  documentation  |     Version:  trunk
 Keywords:                 |
 A lot of the best practices have changed with 2.0 and sadly I haven't had
 time yet to go thru the documentation we have to correct.
 Glaring issues:
 1) How to create geometry tables.
 2) As strk pointed out -- how to define indexes on tables
 including example of an nd index.
 3) How to install/upgrade.  This will change for 9.1, and I haven't put in
 the new extension install approach yet since I don't have an upgrade
 extension script finalized yet so the old way is still the best way for
 9.1 (while 2.0 is in flux).
 4) I'm sure we've still got some deprecated function calls in the docs
 too.
 Anyrate if people want to help out scanning the docs for things that no
 longer make sense in 2.0, and just tack it to this ticket, that would be
 helpful.  Patches welcome.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1288>
