[postgis-devel] [PostGIS] #1288: Update Best practices
PostGIS trac at osgeo.org
Sat Nov 12 07:53:21 PST 2011
 Reporter:  robe           |       Owner:  robe
     Type:  task           |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.0
Component:  documentation  |     Version:  trunk
 Keywords:                 |
Description changed by robe:
Old description:
> A lot of the best practices have changed with 2.0 and sadly I haven't had
> time yet to go thru the documentation we have to correct.
> Glaring issues:
> 1) How to create geometry tables.
> 2) As strk pointed out -- how to define indexes on tables
> including example of an nd index.
> 3) How to install/upgrade.  This will change for 9.1, and I haven't put
> in the new extension install approach yet since I don't have an upgrade
> extension script finalized yet so the old way is still the best way for
> 9.1 (while 2.0 is in flux).
> 4) I'm sure we've still got some deprecated function calls in the docs
> too.
> Anyrate if people want to help out scanning the docs for things that no
> longer make sense in 2.0, and just tack it to this ticket, that would be
> helpful.  Patches welcome.
New description:
 Glaring issues:
 3) How to install/upgrade.  This will change for 9.1, and I haven't put in
 too.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1288#comment:1>
