[postgis-devel] [PostGIS] #1292: ST_SnapToGrid returns a value out of range
PostGIS trac at osgeo.org
Sun Nov 13 16:14:17 PST 2011
 Reporter:  realityexists  |       Owner:  pramsey
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.0.0
Component:  postgis        |     Version:  trunk
 Keywords:                 |
 PostGIS 2.0.0 as of 2011-11-08
 I've found some odd behaviour in ST_SnapToGrid, which looks like a bug.
 When I run
 SELECT ST_SnapToGrid(ST_Transform(ST_GeomFromText('POINT(180 50)',
 4269), 4326), 0.00001)::geography
 an error is returned:
 ERROR:  Coordinate values are out of range [-180 -90, 180 90] for
 GEOGRAPHY type
 Calling ST_AsText() on the same geometry returns "POINT(180 50)", as
 expected. Interestingly, if I either decrease or even increase the
 precision the error does not occur. Eg. this works fine:
 4269), 4326), 0.000001)::geography
 It's only the value 0.0001 that seems to cause a problem.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1292>
