[postgis-devel] [PostGIS] #1289: Override GeometryType for TopoGeometry
PostGIS trac at osgeo.org
Tue Nov 15 08:12:29 PST 2011
 Reporter:  strk         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.0.0
Component:  topology     |     Version:  trunk
 Keywords:               |
Comment(by strk):
 Robe: I've been suggested to look at the CREATE EXTENSION thing, as it
 does support specifying a schema to install all objects in. In particular,
 can you check if it changes any database specific setting, so that you end
 up with having the extension schema appended in your search_path?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1289#comment:6>
