[postgis-devel] [PostGIS] #1289: Override GeometryType for TopoGeometry
Pierre Racine Pierre.Racine at sbf.ulaval.ca
Tue Nov 15 08:22:27 PST 2011
L'hyperlien vers science citoyenne ne fonctionne pas...
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
> bounces at postgis.refractions.net] On Behalf Of PostGIS
> Sent: Tuesday, November 15, 2011 11:12 AM
> Cc: postgis-devel at postgis.refractions.net
> Subject: Re: [postgis-devel] [PostGIS] #1289: Override GeometryType for
> TopoGeometry
>  Reporter:  strk         |       Owner:  strk
>      Type:  enhancement  |      Status:  new
>  Priority:  medium       |   Milestone:  PostGIS 2.0.0
> Component:  topology     |     Version:  trunk
>  Keywords:               |
> Comment(by strk):
>  Robe: I've been suggested to look at the CREATE EXTENSION thing, as it  does
> support specifying a schema to install all objects in. In particular,  can you check
> if it changes any database specific setting, so that you end  up with having the
> extension schema appended in your search_path?
> Ticket URL: <http://trac.osgeo.org/postgis/ticket/1289#comment:6>
> PostGIS <http://trac.osgeo.org/postgis/> The PostGIS Trac is used for bug,
> enhancement & task tracking, a user and developer wiki, and a view into the
> subversion code repository of PostGIS project.
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
