[postgis-devel] [PostGIS] #1303: [PATCH] shp2pgsql does not respect PGCLIENTENCODING
PostGIS trac at osgeo.org
Thu Nov 17 02:50:15 PST 2011
  Reporter:  etourigny      |       Owner:  mcayland
      Type:  defect         |      Status:  closed
  Priority:  medium         |   Milestone:  PostGIS 1.5.4
 Component:  loader/dumper  |     Version:  1.5.X
Resolution:  wontfix        |    Keywords:  shp2pgsql, PGCLIENTENCODING
Changes (by mcayland):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 The reason that we don't do anything with the PGCLIENTENCODING variable is
 because shp2pgsql doesn't use PostgreSQL to perform the encoding
 conversion, but instead uses the iconv library.
 Both PostgreSQL and iconv have different sets of supported conversion
 tables (and even different names in some cases), and so there is no
 guarantee that an encoding specified in PGCLIENTENCODING would necessarily
 either exist or work in the same way when being used with iconv. Hence I
 am closing this as "won't fix".
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1303#comment:1>
